How to create material
Akane Ito
Akane Ito Member Posts: 39
10 Comments First Anniversary 5 Likes Name Dropper
The materials can be created using the following method, but it fails when specifying the material name as a variable.
(When adding materialname = "bb" and rewriting matl1 = engineeringData1.CreateMaterial(Name= "aa")
as matl1 = engineeringData1.CreateMaterial(Name= materialname), it fails.)
Please tell me the solution.
import wbjn
pyCmd = '''
system1 = GetSystem(Name="SYS 5")
engineeringData1 = system1.GetContainer(ComponentName="Engineering Data")
matlProp1 = matl1.CreateProperty(
Name="Mooney-Rivlin",
Definition="2 Parameter",
Qualifiers={"Definition": "2 Parameter", "Behavior": ""})
matlProp1.SetData(
Index=-1,
Variables=["Material Constant C10"],
Values=[["0.69 [MPa]"]])
matlProp1.SetData(
Variables=["Material Constant C01"],
Values=[["0 [MPa]"]])
matlProp1.SetData(
Variables=["Incompressibility Parameter D1"],
Values=[["0 [MPa^-1]"]])
wbjn.ExecuteCommand(ExtAPI, pyCmd)
  • Erik Kostson
    edited October 2024
    Hi
    The code you posted seems ok and runs from both WB and within Mechanical (script console).
    Can you explain in more detail where the issue is in much more detail?
    Also add a series of steps which cause this issue so forum members can reproduce it,
    In that way it is easier for forum members to provide feedback.
    Erik
  • Akane Ito
    Hi Erik.
    This code fails when executed.
    (The bold text indicates the changes from the previous version.)
    import wbjn
    materialname = "bb"
    pyCmd = '''
    matlProp1.SetData(
    Index=-1,
    matlProp1.SetData(
    matlProp1.SetData(
  • AlexGh
    AlexGh Member Posts: 27
    Hello. Maybe this is the problem?
    import wbjn
    materialname = "bb"
    pyCmd = '''
    matl1 = engineeringData1.CreateMaterial(Name="{}")
    Qualifiers={{"Definition": "2 Parameter", "Behavior": ""}})
    matlProp1.SetData(
    Index=-1,
    matlProp1.SetData(
    matlProp1.SetData(
    '''.format(materialname)
  • AlexGh
    I added string formatting to write the value of materialName into the string variable pyCmd.
  • Erik Kostson
    Very helpful AlexGh - that works good
  • Akane Ito
    Thank you!!!
    It worked well.
