How to import heating flux obtain from Speos to LSDYNA
DP
Member, Employee Posts: 4
Hi everyone, I would like to map heating flux from Speos to LSDYNA.
The Speos Absorption file is defined as x,y,z,absorption and will use a different mesh from LSDYNA
import pandas as pd from scipy.interpolate import griddata # Import the Speos absorption file (csv)(x,y,z,Absorption) Speos_Absorption = pd.read_csv('Speos_Absorption.csv') # Import the lsdyna nodes coordinates (csv)(x,y,z) Nodes = pd.read_csv('lsdyna_nodes.csv') # Interpolation # 0 is used by to fill in for requested points outside of the convex hull of the input points Nodes['Absorption'] = griddata(Speos_Absorption[['x', 'y', 'z']].values, Speos_Absorption['Absorption'].values, Nodes[['x', 'y', 'z']].values, method='linear', fill_value=0) # Convert W/m² (m.kg.s) to mW/mm² (mm.t.s) unit_scale = 1E-3 # Negative flux direction (into the volume) flux_direction = -1 Nodes['Absorption'] = Nodes['Absorption'] * unit_scale * flux_direction # Import the segment set (n1,n2,n3,n4) that correspond to the face to map segment_set = pd.read_csv('set_segment_face.csv') # Create a dictionary to map node id to mlc mlc_dict = Nodes.set_index('nid')['Absorption'].to_dict() # Add new columns mlc1 to mlc4 to segment_set segment_set['mlc1'] = segment_set['n1'].map(mlc_dict) segment_set['mlc2'] = segment_set['n2'].map(mlc_dict) segment_set['mlc3'] = segment_set['n3'].map(mlc_dict) segment_set['mlc4'] = segment_set['n4'].map(mlc_dict) # Define the template dyna_temp_original = """*BOUNDARY_FLUX_SEGMENT $# n1 n2 n3 n4 {0},{1},{2},{3} $# lcid mlc1 mlc2 mlc3 mlc4 loc nhisv unused 0,{4:.7g},{5:.7g},{6:.7g},{7:.7g},0,0\n""" # Open the file for writing with open("Boundary_Flux_Segment.k", "w") as dyna_fh: dyna_fh.write("*KEYWORD\n") # Iterate over each row in segment_set for index, row in segment_set.iterrows(): dyna_temp = dyna_temp_original.format( int(row['n1']), int(row['n2']), int(row['n3']), int(row['n4']), float(row['mlc1']), float(row['mlc2']), float(row['mlc3']), float(row['mlc4']) ) dyna_fh.write(dyna_temp) dyna_fh.write("*END\n") print("Boundary_Flux_Segment.k file has been created successfully.") # Define the template dyna_temp_original = """*ELEMENT_SHELL_THICKNESS $# eid pid n1 n2 n3 n4 n5 n6 n7 n8 {0},1,{1},{2},{3},{4} $# thic1 thic2 thic3 thic4 beta {5:.7g},{6:.7g},{7:.7g},{8:.7g},0.0\n""" # Open the file for writing with open("ELEMENT_SHELL_THICKNESS.k", "w") as dyna_fh: dyna_fh.write("*KEYWORD\n") # Iterate over each row in segment_set for index, row in segment_set.iterrows(): dyna_temp = dyna_temp_original.format( index+1, int(row['n1']), int(row['n2']), int(row['n3']), int(row['n4']), float(abs(row['mlc1'])),float(abs(row['mlc2'])),float(abs(row['mlc3'])),float(abs(row['mlc4'])) ) dyna_fh.write(dyna_temp) dyna_fh.write("*END\n") print("ELEMENT_SHELL_THICKNESS.k file has been created successfully.") # Once generated, please open the file in LS-Prepost and save it to the version you are using.
1
