Is there any good way to use code check if the geometry is Visible?
ZZ.tang
ZZ.tang Member Posts: 23
ANSYS mechanical
version 2021r2 & 2023R1
Is there any good way to use code check if a geometry is Visible?
The geometries include the body\face\edge.
  • AlexGh
    AlexGh Member Posts: 27
    Hi ZZ.tang!
    For example, like this:
    # body: Ansys.ACT.Automation.Mechanical.Body
    body = ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.Body)[0]
    isBodyVisible = body.Visible
    body.Visible = True # Show body
    body.Visible = False # Hide body
    # part: Ansys.ACT.Automation.Mechanical.Part
    part = ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.Part)[0]
    isPartVisible = part.Visible
    part.Visible = True # Show part
    part.Visible = False # Hide part
  • Erik Kostson
    Hello
    not sure what the question is here (perhaps there is none :))?
    If you are having any issues with the script, or u would like to ask something, please expand and explain a bit more in detail and we will then try and help.
    thank you
    Erik
  • ZZ.tang
    My question> @AlexGh said:
    Hi ZZ.tang!
    Thanks AlexGh Eric,
    let me try to explain my question more clearly.
    I'm trying to use "DataModel.GeoData.GeoEntityById(geoid)"
    to get a "Ansys.ACT.Common.Geometry.GeoBodyWrapper \ GeoFaceWrapper \GeoEdgeWrapper"
    I want to know if the Geo****Wrapper has been hidden in GUI.
    Or is there any good way to check if a "Geo****Wrapper" is belonging to a "DataModelObjectCategory"
    Thanks!
  • Erik Kostson
    edited October 2024
    Hi
    A geobody does not have such property (check if visible - see below link on the difference between the 2 bodies which can be confusing)
    One can though combine the above script, and getting the Tree body from a Geo body , and then checking if the Tree body is visible or not (above script).
    (see below the difference between the two type of bodies and how to obtain them)
    https://discuss.ansys.com/discussion/2288/whats-the-difference-between-tree-geometry-and-geodata-in-mechanical-api
    All the best
    Erik
  • ZZ.tang
    @Erik Kostson said:
    Hi
    All the best
    Erik
    Thanks Erik, this is very helpful for me.
