How can I restart a Transient Thermal Analysis?
oliadag
oliadag Member Posts: 4
Hello everyone,
I’m working on a script to automatically generate a restart analysis for a transient thermal analysis once the calculation is completed. Ideally, I would like to create a restart object within the existing tree structure rather than generating a new system. However, insights on both approaches would be helpful.
I came across this discussion that provided some useful information, but it seems like it is not applicable to transient thermal analysis:
https://discuss.ansys.com/discussion/3062/restart-analysis-in-mechanical
Does anyone have experience with this or any suggestions?
Best regards,
Olia
    Use a python code object for after solve or after post callback. Then use this code to create a restart analysis
    Analysis = Model.Analyses[0]  #Your analysis here
    Settings = Analysis.AnalysisSettings
    Settings.RetainFilesAfterFullSolve=RestartRetainFilesType.Yes
    Ext = ExtAPI.ExtensionManager.GetExtensionByName("RestartAnalysis")
    ExtMod = Ext.GetModule()
    ExtMod.createRestartAnalysis(Analysis)
    Woops, just realize you want a thermal analysis restart. That is not supported natively with Mechanical or the restart Add On. You would need to do that through command snippets.
  • oliadag
    Thank you, Mike! I successfully managed the restart by using the AddCommandSnippet() method to insert a command snippet.
