Get DPF results by harmonic index
Jim Kosloski
Member, Employee Posts: 31
For a cyclic model is there a way to get results at a specific harmonic index? Example: I want to get results for harmonic index 2, mode 1
Use something like this to get the Time/Freq Support object:
Analysis = Model.Analyses[1] ds = dpf.DataSources(Analysis.ResultFileName) TFS_Op = dpf.operators.metadata.time_freq_provider() TFS_Op.inputs.data_sources.Connect(ds) TFS= TFS_Op.outputs.time_freq_support.GetData() print TFS
You will get an output like this, that lists the harmonic index. You can then setup a time scoping on the typical DPF results operator to get the correct set (both mode and harmonic index)
DPF Time/Freq Support: Number of sets: 72 Cumulative Frequency (Hz) LoadStep Substep Harmonic index 1 383.044743 1 1 0.000000 2 740.967050 1 2 0.000000 3 1469.791028 1 3 0.000000 4 1729.302253 1 4 0.000000 5 2008.730330 1 5 0.000000 6 2628.583526 1 6 0.000000 7 485.840944 2 1 1.000000 8 485.840944 2 2 1.000000 9 715.620560 2 3 1.000000 10 715.620560 2 4
You can also look at the operators built for cyclic expansion, but in general the time/freq. support data will help inform the time scoping for this operator.
op = dpf.operators.result.cyclic_expanded_displacement() # operator instantiation op.inputs.time_scoping.Connect(my_time_scoping)# optional op.inputs.mesh_scoping.Connect(my_mesh_scoping)# optional op.inputs.fields_container.Connect(my_fields_container)# optional op.inputs.streams_container.Connect(my_streams_container)# optional op.inputs.data_sources.Connect(my_data_sources) op.inputs.bool_rotate_to_global.Connect(my_bool_rotate_to_global)# optional op.inputs.all_dofs.Connect(my_all_dofs)# optional op.inputs.sector_mesh.Connect(my_sector_mesh)# optional op.inputs.requested_location.Connect(my_requested_location)# optional op.inputs.read_cyclic.Connect(my_read_cyclic)# optional op.inputs.expanded_meshed_region.Connect(my_expanded_meshed_region)# optional op.inputs.cyclic_support.Connect(my_cyclic_support)# optional op.inputs.sectors_to_expand.Connect(my_sectors_to_expand)# optional op.inputs.phi.Connect(my_phi)# optional my_fields_container = op.outputs.fields_container.GetData() my_expanded_meshes = op.outputs.expanded_meshes.GetData()
@Mike.Thompson I get that I can list the information, but I need to get it programmatically. Say I want to write a script that gets the displacements for Harmonic Index 3, Mode 3. How do I do that?
