Mapdl pool run batch error
Dear all,
I am using MapdlPool and the command run_batch.
The code is launching properly and the pool is created.
Randomly, the computation fails and I receive the following error
raise MapdlExitedError(
ansys.mapdl.core.errors.MapdlExitedError: MAPDL server connection terminated with the following error
<_MultiThreadedRendezvous of RPC that terminated with:
status = StatusCode.UNAVAILABLE
details = "Connection reset"
debug_error_string = "UNKNOWN:Error received from peer ipv4:.... {grpc_message:"Connection reset", grpc_status:14, created_time:"......"}"
In some cases the mapdl session reboots and the computation continues (although it takes some time for the rebooting)
In other cases, I get
PyMAPDL is taking longer than expected to connect to an MAPDL session.
Checking if there are any available licenses...
and the computation stops completly.
Do you know how to prevent such issues?
I have tried running the pool with a lower number of instances as well. To no avail.
Best,
Hi
Please post here (as an issue or discussion if it is not an issue):
I've created an issue as you can see above, so hopefully someone will be able to help out!
