How to reverse the orientation
Akane Ito
Akane Ito Member Posts: 39
10 Comments First Anniversary 5 Likes Name Dropper
How can I reverse the orientation in a script, as shown in the figure below?
Best Answers
  • Erik Kostson
    edited October 2024 Answer ✓
    Hi @Akane Ito
    You are showing a picture of the coordinate system definition/details.
    See here how to set that up (coordinate system):
    https://discuss.ansys.com/discussion/1302/create-and-rotate-coordinate-system
    Let us know if this helps or if you refer to something else (explain more if that is the case, e.g., if you refer to a force direction)
    If it is a force we can get the current direction (force_33 is the defined force object) and then flip it (by vector multiplication):
    Vec=force_33.Direction # current direction
    Nvec=Ansys.ACT.Math.Vector3D( float(Vec.X) * -1.00,float(Vec.Y) * -1.00, float(Vec.Z)*-1.00) # flip Vec
    force_33.Direction=Nvec
  • Erik Kostson
    Hope the above helps
