I am trying to append some data to a CSV file in SpaceClaim scripting environment using the commands shown below, but it is NOT allowing me to give newline = ' ' argument for the open function. This syntax is running perfectly alright when used in Standalone Python environment (via Spyder).
If I remove newline = ' ' argument, SpaceClaim did not complain, but the output CSV file has been generated with an Empty Row between each data line, which I want to avoid. Any tips/tricks to resolve this would be so helpful. Thank you.
# Appending Data to an Existing CSV file
file = open(csv_robustness_input_path, 'a', newline = '')
writer = csv.writer(file)
data_to_append = []
for i in range(len(Opt_Param_Name)):
data = [Opt_Param_Name[i],"Optimization",Opt_Param_Ref_Value[i],0,0, "",1,"", "REAL", "Continuous", str(Opt_Param_Min[i])+":"+str(Opt_Param_Max[i]), "","", "", "",""]
data_to_append.append(data)
writer.writerows(data_to_append)
file.close()
# End
