Mechanical addon issue
rfichepo
Member, Employee Posts: 1 ✭✭✭
When I try to load two of my Mechanical extensions at the same time, I have the message in the logger : "An item with the same key has already been added" even if the guid in the xml are different between those two extensions. Would you have any idea what cause this error message?
Thanks.
@rfichepo if they are different names and GUIDs, I would suggest try cleaning up the AppData (rename v242)
%appdata%\Ansys\v242
