Hi team, how can i read/get the above automation variable data through scripting..?
@James Derrick Any solution..?
Hi @Naveen Kumar Begari Could you provide a bit more context around what you're trying to do and why? I'm afraid it can sometimes be quite tough for our subject matter experts to help unless they know the problem in detail.
Hi @James Derrick
I wants to change the fluid flow in Motorcad Thermal module with respect to an output variable "Temp_Winding_Max".
For example, if the output winding temperature is less than 100deg, the inlet fluid flow should be 8, otherwise it should be 6.
However when Im trying to call the output variable in the script, the written variable is not working.
Would like to know whether we can call an output variable value in script.
related to PyMotorCAD | VB Script.
Hi @Naveen Kumar Begari I see this is a duplicate problem of https://discuss.ansys.com/discussion/comment/5570 where you have already received an answer. Please continue any discussion there as I am closing this post.
