How do you output simulation data to a hdf5 file?
Eric Stamper
Eric Stamper Member, Employee Posts: 7
Second Anniversary Ansys Employee First Comment Photogenic
Given any number of different dpf fields of data (for the same time and mesh scoping), how do you create one hdf5 file that contains all this combined information?
  • Eric Stamper
    edited December 2024 Answer ✓
    Answer, with help from Ayush:
    def create_h5_file(path, *args):
        Create a .h5 file to the given path from the data provided (DPF field/Fileds Container)
        try:
            hdf5_op = dpf.operators.serialization.serialize_to_hdf5() # operator instantiation
            hdf5_op.inputs.file_path.connect(path)
            for i, data in enumerate(args):
                hdf5_op.connect(i + 3, data)
            hdf5_op.inputs.export_floats.connect(False)  # maintain double precision
            hdf5_op.run()
            return True
        except Exception as e:
            return False
    # Define 3 differents sets of data to combine into 1 hdf5 file.
    disp_op = dpf.operators.result.displacement()
    disp_op.inputs.data_sources.connect(data_sources)
    disp_op.inputs.mesh_scoping.connect(mesh_scoping)
    disp_op.inputs.time_scoping.connect(time_scoping)
    nd_disps = disp_op.outputs.fields_container.get_data()
    node_coords_op = dpf.operators.mesh.node_coordinates()
    node_coords_op.inputs.mesh.connect(mesh_from_scoping)
    nd_coords=node_coords_op.outputs.coordinates_as_field.get_data()
    tfs_op = dpf.operators.metadata.time_freq_provider()
    tfs_op.inputs.data_sources.connect(data_sources)
    tfs = tfs_op.outputs.time_freq_support.get_data()
    # Write all fields into one .h5 file
    out_path = r"D:\working_dir\combined.h5"
    create_h5_file(out_path, nd_disps, nd_coords, tfs)
