How to modify the selection information Column Control settings?
Landon Mitchell Kanner
What is the script to activate the ‘Mass’, ‘Centroid’, and ‘Moment of Inertia’ in the section information Column Control panel? Because, by default, some quantities are not activate, I need to force turn those on then I can export the section information.
  • Landon Mitchell Kanner
    ExtAPI.Application.ScriptByName("jscript").ExecuteCommand("DS.Script.CCO_Body_ShowMass=true")
    ExtAPI.Application.ScriptByName("jscript").ExecuteCommand("DS.Script.CCO_Body_ShowCentroid=true")
    ExtAPI.Application.ScriptByName("jscript").ExecuteCommand("DS.Script.CCO_Body_ShowMomentOfInertia=true")
    ExtAPI.Application.ScriptByName("jscript").ExecuteCommand("DS.Script.CCO_Body_ShowGeneral=true")
    You can see complete list of options in the function SetDefaultColumnControlOption() at line 368 here:
    C:\Program Files\ANSYS Inc\v242\aisol\DesignSpace\DSPages\scripts\DSSelectionInfoPaneScript.js
    See also: https://discuss.ansys.com/discussion/4534/open-the-selection-information-panel-in-mechanical/
