Python Result shall wait until results evaluated
I have a question regarding Python Results in Mechanical. I am automatically generating Python results using a lot of code, structured as follows:
def createPicture(current_path):
import toolbar
toolbar.DoUndeformedWireFrameResultView(ExtAPI)
Graphics.ViewOptions.ResultPreference.ExtraModelDisplay =
MechanicalEnums.Graphics.ExtraModelDisplay.UndeformedWireframe
scfOut = ExtAPI.DataModel.GetObjectsByName('Outside SCF overview')[0]
imgPath = current_path + "\Results\SCFResOut.png"
cam = Graphics.Camera cam.FocalPoint = Point([0, 7.5, 0], 'm') cam.ViewVector = Vector3D(1, 0, 0) cam.UpVector = Vector3D(0, 1, 0) cam.SceneHeight = Quantity(15, 'm') cam.SceneWidth = Quantity(botRad, 'm') img = scfOut.AddImage() img.SourceType = 1 img.ImagePath = imgPath ExtAPI.Graphics.ExportScreenToImage(imgPath )
def post_started(sender, analysis): # Do not edit this line
define_dpf_workflow(analysis)
# Here comes my code, which is executed and performs some conversions, etc.
createPicture(path)
Now, the script should wait until the results are loaded and evaluated. Once they are created, the script should take a picture and save it. However, I can't find a function that waits and only creates the images after the evaluation is complete.
The issue is that if I let the script create the images while the evaluation is still in progress, it only produces a picture of the geometry without the results.
Hi
This example creates images when the results are done (after post ):
All the best
Erik
Perhaps I didn't phrase my question entirely correctly, but the issue has been resolved as I found a solution. Nonetheless, thank you for your quick response.
Hi @SchluppIng - can you post your solution here as others might find this useful if they encounter a similar issue.
Erik0 -
First of all I created an ACT which calls a function to create an event based python code.
Example func:def addPythonCodeEvent(analysis, currentPath): import os #Add some path for self created libs/funcs. paths_to_append = [os.path.join(currentPath, folder) for folder in os.listdir(currentPath) if os.path.isdir(os.path.join(currentPath, folder))] paths_to_append.append(currentPath) for path in paths_to_append: if path not in sys.path: path = os.path.join(path) sys.path.append(path) import TextReader import re sol = analysis.Solution pyCodeEvent = sol.AddPythonCodeEventBased() pyCodeEvent.TargetCallback = PythonCodeTargetCallback.OnAfterPost pictureCreatorFile = currentPath + "\\MechPyRes\\PySCFPictureCreator.py" pictureCreatorContent = TextReader.read_text_file(pictureCreatorFile) new_path_out = str(currentPath + "\\Results\\SCF_Overview_Outside.png") pictureCreatorContent = re.sub(r'fPathOut\s*=\s*".*?"', 'fPathOut = r\'{}\''.format(new_path_out), pictureCreatorContent) #Here the py script from below is added the the python event base code pyCodeEvent.Text = pictureCreatorContent pyCodeEvent.Name = "SCF_Picture_Creator" pyCodeEvent.PropertyByName("Suppressed").InternalValue = True
This is the python event based code:
def after_post(this, solution): #Do some personal checks for whatever if ExtAPI.DataModel.GetObjectsByName('Outside SCF overview'): import toolbar toolbar.DoUndeformedWireFrameResultView(ExtAPI) #Disable ruler for output Graphics.ViewOptions.ShowRuler = False #Disable mesh etc. Graphics.ViewOptions.ResultPreference.ExtraModelDisplay = MechanicalEnums.Graphics.ExtraModelDisplay.UndeformedWireframe #Create empty variable for output pathes, will be overwritten fPathOut = "C:\\" fPathIn = "C:\\" #Get results from python code scf = ExtAPI.DataModel.GetObjectsByName('PyResults')[0] #Set output settings for image gset = Ansys.Mechanical.Graphics.GraphicsImageExportSettings() gset.CurrentGraphicsDisplay = False gset.Width = 750 gset.Height = 1000 gset.Background = GraphicsBackgroundType.White gset.Capture = GraphicsCaptureType.ImageAndLegend gset.FontMagnification = 0.6 #Active outside SCF, set camera and export image scfOut.Activate() #Find max value to display maxValOut = 0.0 for prop in scfOut.Properties: if "SCF Bending FreeEdge" in prop.Name: scf = scfOut.GetCustomPropertyByPath(prop.Name) maxValOut = scf.Value #Setup legend lsOut = Ansys.Mechanical.Graphics.Tools.CurrentLegendSettings().MakeCopy() #ls = Ansys.Mechanical.Graphics.Tools.LegendSettings() lsUnitOut = lsOut.Unit lsOut.SetMinMax(Quantity(1.0, lsUnitOut), Quantity(maxValOut, lsUnitOut)) #Set camera orientation ExtAPI.Graphics.Camera.SetSpecificViewOrientation(ViewOrientationType.Right) ExtAPI.Graphics.Camera.SetFit() #Export graphics, import graphics to the results and rename Graphics.ExportImage(fPathOut, GraphicsImageExportFormat.PNG, gset) imgOut = scfOut.AddImage(fPathOut) imgOut.Name = "SCF Overview Outside"
Probably not the best soultion, but it works
