starting fluent on a HPC cluster using pyfleunt
Michael Salas
Member Posts: 2
I am trying to run a fluent simulation accross multiple nodes of a HPC using pyfluent to open the case file, initialize it and run it. All the settings for the simulation are already done and saved ahead of time. The pyfluent script works when I submit the job on one node but when I submit it on multiple fluent times out when launching. I thought this was a MPI issue orginially but I am not sure anymore. I've attached the batch script, the pyfluent script and the error when running on multiple nodes below. If you need anymore info to help me I'll be happy to get it to you. Thanks.
batch script:
#!/bin/bash #SBATCH -J ansysjob # job name #SBATCH -e ansysjob.%j.err # error file name #SBATCH -o ansysjob.%j.out # output file name #SBATCH -N 1 # request 2 nodes #SBATCH -n 128 # request 128 cores #SBATCH -t 0:20:00 # designate max run time #SBATCH -A DDM23001 # charge job to myproject #SBATCH -p development # designate queue # Load necessary modules module load python3/3.9.7 module load ansys # Define Fluent environment export AWP_ROOT232='/scratch/tacc/apps/ANSYS/2023R2/v232' # set library path for Fluent shared libraries export LD_LIBRARY_PATH=/scratch/tacc/apps/ANSYS/2023R2/v232/fluent/lib/lnamd64:$LD_LIBRARY_PATH # pre-create blank output file touch /scratch/10223/mjs7392/jcat/fluent_output.log # give permissions to the pyfluent script chmod 700 /scratch/10223/mjs7392/jcat/intake_script.py # Run the Python script with MPI configuration python /scratch/10223/mjs7392/jcat/intake_script.py > /scratch/10223/mjs7392/jcat/fluent_output.log 2>&1
pyfluent script:
# created by Michael Salas import ansys.fluent.core as pyfluent import os import time # Import the time module for tracking execution time # set environment for Fluent location os.environ['AWP_ROOT232'] = '/scratch/tacc/apps/ANSYS/2023R2/v232' # Path to Fluent installation # path to the Fluent case file (HDF5 case file) case_file = r'/scratch/10223/mjs7392/jcat/jcat_files/dp0/FLTG/Fluent/FLTG-Setup-Output.cas.h5' # Start tracking time start_time = time.time() # initialize a Fluent session solver = pyfluent.launch_fluent( mode="solver", precision=pyfluent.Precision.DOUBLE, dimension=pyfluent.Dimension.THREE ) # read the HDF5 case file ('.cas.h5') solver.file.read_case(file_type="case", file_name=case_file) solution = solver.settings.solution # initialize the solution solution.initialization.standard_initialize() print("INITIALIZED") # run the calculation solution.run_calculation.dual_time_iterate() print("RAN CALC") # End tracking time end_time = time.time() # Calculate elapsed time in seconds elapsed_time = end_time - start_time # Format the elapsed time in a readable way (e.g., HH:MM:SS) hours, rem = divmod(elapsed_time, 3600) minutes, seconds = divmod(rem, 60) formatted_time = f"{int(hours):02}:{int(minutes):02}:{seconds:05.2f}" # Define the output log file path log_file_path = "/scratch/10223/mjs7392/simulation_time_log.txt" # Write the elapsed time to the log file with open(log_file_path, "w") as log_file: log_file.write(f"Simulation completed successfully.\n") log_file.write(f"Total job run time: {formatted_time} (HH:MM:SS)\n")
The error:
Host spawning Node 0 on machine "c304-005.ls6.tacc.utexas.edu" (unix). /scratch/tacc/apps/ANSYS/2023R2/v232/fluent/fluent23.2.0/bin/fluent -r23.2.0 3ddp -flux -node -t128 -pmpi-auto-selected -mpi=intel -cnf=c304-005:64,c304-006:64 -ssh -mport 129.114.41.77:129.114.41.77:33065:0 Starting /scratch/tacc/apps/ANSYS/2023R2/v232/fluent/fluent23.2.0/multiport/mpi/lnamd64/intel2021/bin/mpirun -f /tmp/fluent-appfile.mjs7392.2114516 --rsh=ssh -genv FLUENT_ARCH lnamd64 -genv I_MPI_DEBUG 0 -genv I_MPI_ADJUST_GATHERV 3 -genv I_MPI_ADJUST_ALLREDUCE 2 -genv I_MPI_PLATFORM auto -genv PYTHONHOME /scratch/tacc/apps/ANSYS/2023R2/v232/fluent/fluent23.2.0/../../commonfiles/CPython/3_10/linx64/Release/python -genv FLUENT_PROD_DIR /scratch/tacc/apps/ANSYS/2023R2/v232/fluent/fluent23.2.0 -genv FLUENT_AFFINITY 0 -genv I_MPI_PIN enable -genv KMP_AFFINITY disabled -machinefile /tmp/fluent-appfile.mjs7392.2114516 -np 128 /scratch/tacc/apps/ANSYS/2023R2/v232/fluent/fluent23.2.0/lnamd64/3ddp_node/fluent_mpi.23.2.0 node -mpiw intel -pic mpi-auto-selected -mport 129.114.41.77:129.114.41.77:33065:0 pyfluent.launcher ERROR: Exception caught - TimeoutError: The launch process has timed out. Traceback (most recent call last): File "/home1/10223/mjs7392/.local/lib/python3.9/site-packages/ansys/fluent/core/launcher/standalone_launcher.py", line 253, in __call__ raise ex File "/home1/10223/mjs7392/.local/lib/python3.9/site-packages/ansys/fluent/core/launcher/standalone_launcher.py", line 233, in __call__ _await_fluent_launch( File "/home1/10223/mjs7392/.local/lib/python3.9/site-packages/ansys/fluent/core/launcher/launcher_utils.py", line 59, in _await_fluent_launch raise TimeoutError("The launch process has timed out.") TimeoutError: The launch process has timed out. The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/scratch/10223/mjs7392/jcat/intake_script.py", line 17, in solver = pyfluent.launch_fluent( File "/home1/10223/mjs7392/.local/lib/python3.9/site-packages/ansys/fluent/core/utils/deprecate.py", line 49, in wrapper return func(*args, **kwargs) File "/home1/10223/mjs7392/.local/lib/python3.9/site-packages/ansys/fluent/core/utils/deprecate.py", line 49, in wrapper return func(*args, **kwargs) File "/home1/10223/mjs7392/.local/lib/python3.9/site-packages/ansys/fluent/core/launcher/launcher.py", line 285, in launch_fluent return launcher() File "/home1/10223/mjs7392/.local/lib/python3.9/site-packages/ansys/fluent/core/launcher/standalone_launcher.py", line 296, in __call__ raise LaunchFluentError(self._launch_cmd) from ex ansys.fluent.core.launcher.error_handler.LaunchFluentError: Fluent Launch string: nohup /scratch/tacc/apps/ANSYS/2023R2/v232/fluent/bin/fluent 3ddp -t128 -cnf=c304-005:64,c304-006:64 -gu -sifile=/tmp/serverinfo-xjyx628q.txt -nm &
I figured out what was wrong, I needed to add the argument additional_arguments="-mpi=openmpi" when launching fluent
