When I run this code in visual studio, it prompts "NameError: name 'MechanicalPanelEnum' is not defined". Is there any way to export this data in Python 3.9 environment?
You probably need to use the full path:ExtAPI.UserInterface.GetPane(Ansys.ACT.Interfaces.Mechanical.MechanicalPanelEnum.TabularData)
But I think you will also need to switch from using embedded PyMechanical to using remote PyMechanical, as you will need to have the GUI running (although you could hide it). Here is a handy reference guide:
https://cheatsheets.docs.pyansys.com/pymechanical_cheat_sheet.png
