PyWorkbench - PyMechanical - WebApp, workflow example required.?
Hi Team, Can I get assistance over the required workflow.? Do we have existing examples?
Here is a PyWorkbench+PyMechanical example:
https://examples.workbench.docs.pyansys.com/version/stable/examples/pymechanical-integration/main.htmlFor creating web apps there are lots of approaches and tech stacks; many of which have lots of examples. Easiest way to get started IMO is to use optiSLang's app generation tool:
https://learninghub.ansys.com/learn/courses/305/ansys-optislang-apps-and-automation
The above training looks a bit dated and probably covers owa apps. Starting at 24.2, I recommend using the newer awa apps instead.2 -
As above PyWorkbench example help documentation broken, please refer to the Github link to see the examples: (https://github.com/ansys/pyworkbench-examples/tree/main/examples/axisymmetric-rotor)
1 -
Hi @Landon Mitchell Kanner Thank you....
Hello @vikas.namd Thank you for your suggestion. I will implement from here1
