Issue Generating Field Plots Using PyAEDT
Hi Everyone,
I am encountering issues while generating and exporting field plots using PyAEDT. The process fails with the following error messages displayed in the AEDT Message Manager as shown in the screenshot:
"Script macro error: Plot H_vector_plot is not valid. Make sure this plot is updated before export"
However, when I perform the same steps manually through the AEDT GUI, the process completes successfully without any errors (as demonstrated in the attached GIF).
Steps To Reproduce:
Use the provided Python code snippet (below) to reproduce the issue. Download and use the sample aedt file from this link.
import ansys.aedt.core
from pathlib import Path
import pyvista as pv
folder_path = Path(r"C:/Users/ch/aedt_sample_file")
file_path =  folder_path.joinpath("Project3.aedt")
desktop = ansys.aedt.core.Desktop()
prj= desktop.load_project(file_path.__str__())
prj.set_auto_open(enable=False)
model = prj.modeler
part_names = model.object_names
post = prj.post  # post_processor
part_list = ['Ground']
for name in part_list:
    obj =  model.get_object_from_name(name)
    if obj.solve_inside:
        h_field_plot = post.create_fieldplot_volume([name],quantity="Vector_H",
                                                    plot_name="H_vector_plot")
    else:
        h_field_plot = post.create_fieldplot_surface(obj.faces,quantity="Vector_H",
                                                    plot_name="H_vector_plot",
                                                    intrinsics=prj.setups[0].default_intrinsics)
    export_status = post.export_field_plot(plot_name = "H_vector_plot",
                            output_dir = "C:/Users/ch/aedt_sample_file",
                            file_name = "h_vector",
                            file_format = 'case')
    h_field_plot.delete()
prj.close_project()
desktop.close_desktop()
The Python code generates the H Vector field plot for the Ground object and attempts to export it into .case format.
Question:
How can I resolve this issue when using PyAEDT? Any insights or suggestions would be greatly appreciated.
Thanks
Regards
  • James Derrick
    James Derrick Administrator, Employee Posts: 314
    admin
    Hello! Thank you for your detailed question, we really appreciate it when people provide full context. Hopefully @Samuel Lopez or @svandenb-dev will be able to help you out. We're all just getting back into the swing of things now that the holidays are over!
