How can I use DPF to get the real constant ID of an element and then get the values of that real constant?
@Jim Kosloski
It is possible to get real_id for elements now:
from ansys.dpf import core as dpf ds = dpf.DataSources(result_path=r"StaticStructural\file.rst") model = dpf.Model(ds) ms =model.metadata.meshed_region op = dpf.operators.metadata.mesh_property_provider() op.inputs.mesh_scoping.connect(ms.elements.scoping) op.inputs.streams_container.connect(model.metadata.streams_provider) op.inputs.property_name.connect('apdl_real_id') fld = op.outputs.property_as_property_field()
But for getting real_contants value, I think operator is not available in 2025.1, It is available in 2025R2 server. Below is example of it.
real_op = dpf.Operator('real_constants_provider') real_op.connect(3, model.metadata.streams_provider) real_constant_data= real_op.eval()
