I can import data using ExtAPI.Application.ImportMesh('./drop.k') on Windows, but it doesn't work on Linux. What should I do?
@xswpp Do you get any error?
@Rajesh Meena said:@xswpp Do you get any error?
In Linux, executing ExtAPI.Application.ImportMesh('./drop.k') does not produce any errors, but no data is imported into PyMechanical. ansys-mechanical-core=0.10.8 ansys-mechanical-env=0.1.4 ansys-api-mechanical=0.1.1
In Windows In Linux
Sorry, The order of the images above is reversed.
@xswpp Unfortunately, there is a bug in LS-DYNA converter on linux. It does not work even when we try to import manually.
I filed a bug (1196503), but I would encourage you to log a support request so that it can be followed up.
