Load output of PyMechanical Script to PyDyna
cardiac.scripter
cardiac.scripter Member Posts: 7
I have a .mechdat file output from a previous sim in PyMechanical. How can I load it as an input mesh for subsequent simulation in PyDyna?
Thanks in advance
  • Erik Kostson
    edited January 13
    Hello
    One approach is in Pymechanical to generate the k file (also define all of the LS-Dyna loads/bc if one wants), which you can then import into pyDyna.
    To generate the k file in pymechanical use:
    analysis = Model.AddLSDynaAnalysis()
    analysis.WriteInputFile('D:\\mypymechkfile.k')
    Then import the k file into PyDyna
    Thank you
    Erik
  • cardiac.scripter
    Hi Erik,
    So construct a model from the mechdat file within PyMechanical with the deformed geometry. Then save that as .k file with the lines above.
    Have I understood you correctly?
    Cheers
  • cardiac.scripter
    Just because I want to use the deformed geometry from the result of the PyMechanical script as the starting geometry for the PyDyna script.
  • cardiac.scripter
    I realised an oversight on my part.
    I need the .rst file.
    However, I am struggling to load the .rst file with PyMechanical. Once in PyMechanical its easy to then follow your instructions.
    Would you suggest opening in pyDPF? I was thinking to go down this route, but I can't find documentation of then saving in PyDyna format.
    Ben
  • Landon Mitchell Kanner
    You might find this discussion useful:
    https://discuss.ansys.com/discussion/3460/which-scripting-part-or-pyansys-modules-can-i-use-to-obtain-results-in-the-avz-format
  • cardiac.scripter
    Hi Landon,
    Thanks for this.
    I have downloaded the library and tried the method.
    It worked, thank you Erik and Landon.
    ```python
    from ansys.mechanical.core import App
    import sys
    from ansys.mechanical.core import global_variables
    library = r"C:\Users\XXX\Scripts\ResultsFileMechReader"
    result_file = r"C:\Users\XXX\StaticStructural\file.rst"
    outfolder = os.path.split(result_file)[0]
    app = App()
    globals().update(global_variables(app))
    sys.path.append(library)
    sys.path.append(r'C:\Program Files\ANSYS Inc\v242\aisol\DesignSpace\DSPages\Python'.format(app.version))
    import RunAPDL
    RunAPDL.Initialize(ExtAPI, Ansys)
    SI, CdbPath = RunAPDL.GetCdbFileFromResultFile(result_file)
    import RunMech
    RunMech.Initialize(ExtAPI, Ansys)
    RunMech.ImportResultsToCurrentSession(CdbPath, result_file, library)
    results =ExtAPI.DataModel.GetObjectsByType(Ansys.Mechanical.DataModel.Enums.DataModelObjectCategory.Result)
    Set units
    ExtAPI.Application.ActiveUnitSystem = MechanicalUnitSystem.StandardNMMdat
    dyna_file = r"C:\Users\XXX\stress_free_mesh.k"
    analysis.WriteInputFile(dyna_file)
  • Erik Kostson
    Hi @cardiac.scripter
    That is great.
    In this way do you export to the LS-Dyna k file a deformed geometry (as per rst file)?
    Erik
  • cardiac.scripter
    Hi Erik,
    Yes I can. Works well.
