If I have multiple fields containers and I want to write them all to a single .h5 file, how can I do this?
serialization.serialize_to_hdf5 operator is deprecated. I am not sure how to use this operator: serialization.hdf5dpf_generate_result_file
Hi @Mike.Thompson, you can try this:
import os import time from ansys.dpf import core as dpf dpf.set_default_server_context(dpf.AvailableServerContexts.premium) filename = #whichever dataSource = dpf.DataSources() dataSource.set_result_file_path(filename) model=dpf.Model(dataSource) # Get Result to Export resultInfoProvider = dpf.operators.metadata.result_info_provider() resultInfoProvider.inputs.data_sources.connect(dataSource) result_info = resultInfoProvider.outputs.result_info() time_supp=dpf.operators.metadata.time_freq_provider(data_sources=dataSource).outputs.time_freq_support() dpf.operators.serialization.hdf5dpf_generate_result_file() migrate_op = dpf.operators.serialization.hdf5dpf_generate_result_file() # operator instantiation migrate_op.inputs.h5_native_compression.connect(1)# gzip type compresision migrate_op.inputs.export_floats.connect(False)# doubles as doubles migrate_op.inputs.filename.connect(filename+"_converted.h5") migrate_op.inputs.time_freq_support_out.connect(time_supp) migrate_op.connect(1,model.metadata.meshed_region) idx=4 fc={} for res in result_info.available_results: print(res.operator_name) op_res=dpf.Operator(res.operator_name) op_res.inputs.data_sources.connect(dataSource) fc[idx]=op_res.outputs.fields_container() migrate_op.connect(idx,res.operator_name) migrate_op.connect(idx,fc[idx]) idx+=2 tic = time.perf_counter() migrate_op.run() toc = time.perf_counter() print(f"Migration Time (s) : {toc - tic:0.4f}")
@Pierre Thieffry , Thanks.
when I run the code below, I see in the .h5 file there is only 1 field in the structure. In the code I have 2 distinct fields, but they simply have the exact same information. It seems DPF is identifying these as identical, and representing them in the structure as the same. Is this expected?
The question leads to the idea of getting this data back into the original form from an .h5 file. I was wondering what would happen since I have F1 added twice to the FC.
How can I get back to the same python data structure where the fields container contains 3 entries, but the first two point to the same field by reference (change in FC[1] will also modify FC[0]).
from ansys.dpf import core as dpf #Make a field of data F1 = dpf.fields_factory.Field(nentities=1, nature=dpf.natures.scalar) scoping = dpf.scoping.Scoping(ids=[1] , location=dpf.locations.zone) F1.scoping=scoping F1.unit='mm' F1.data=[1] #Make another field of data. This is identical to the first field, but still a unique entity F2 = dpf.fields_factory.Field(nentities=1, nature=dpf.natures.scalar) F2.scoping=scoping F2.unit='mm' F2.data=[1] #Add them to fields container. #Add F1 twice at different times. FC = dpf.fields_container.FieldsContainer() FC.add_label('time') FC.add_field({'time':1}, F1) FC.add_field({'time':2}, F1) FC.add_field({'time':3}, F2) #Write .h5 file pin = 4 migrate_op = dpf.operators.serialization.hdf5dpf_generate_result_file() # operator instantiation migrate_op.inputs.filename.connect(r'C:\Users\mthompso\MyData\DeleteThis\DPF for Mission Loading\SameVals.h5') migrate_op.connect(pin,"Something") migrate_op.connect(pin+1,FC) my_data_sources = migrate_op.outputs.data_sources()
@Mike.Thompson , yes DPF identifies that a given entity (field or scoping, ...) is already saved and avoids saving it again. This is beeing said your point is valid, please could you file a defect on this? I will ensure that it's tracked.
