How to import Heat Transfer Coefficient from Fluent to LSDYNA?
DP
Member, Employee Posts: 4
Hi everyone, I would like to Heat Transfer Coefficient from Fluent to LSDYNA.
The HTC file is defined as x,y,z,heat-transfer-coef-wall and will use a different mesh from LSDYNA
import pandas as pd from scipy.interpolate import griddata import matplotlib.pyplot as plt # Import the Fluent convection file (csv) Fluent_Convection = pd.read_csv('HTC_test') length_unit_scale = 1 # Import the nodes coordinates (csv) Nodes = pd.read_csv('nodes_lsdyna_20mm.csv') # Interpolation Nodes['heat-transfer-coef'] = griddata(Fluent_Convection[['x-coordinate', 'y-coordinate', 'z-coordinate']].values*length_unit_scale, Fluent_Convection['heat-transfer-coef-wall'].values, Nodes[['x-coordinate', 'y-coordinate', 'z-coordinate']].values, method='nearest',fill_value=0) # Convert W/m².°C (m.kg.s) to W/m².°C (m.kg.s) heat_unit_scale = 1 Nodes['heat-transfer-coef'] = Nodes['heat-transfer-coef'] * heat_unit_scale # Import the segment set segment_set = pd.read_csv('segment_lsdyna_20mm.csv') # Create a dictionary to map node id to heat-transfer-coef h_dict = Nodes.set_index('nid')['heat-transfer-coef'].to_dict() # Add new columns mlc1 to mlc4 to segment_set segment_set['mlc1'] = segment_set['n1'].map(h_dict) segment_set['mlc2'] = segment_set['n2'].map(h_dict) segment_set['mlc3'] = segment_set['n3'].map(h_dict) segment_set['mlc4'] = segment_set['n4'].map(h_dict) segment_set['mlc'] = segment_set[['mlc1', 'mlc2', 'mlc3', 'mlc4']].mean(axis=1) # Define the template dyna_temp_original = """*BOUNDARY_CONVECTION_SEGMENT $# n1 n2 n3 n4 {0},{1},{2},{3} $# hlcid hmult tlcid tmult loc 0,{4:.7g},0,0,0,0\n""" # Open the file for writing with open("BOUNDARY_CONVECTION_SEGMENT.k", "w") as dyna_fh: dyna_fh.write("*KEYWORD\n") # Iterate over each row in segment_set for index, row in segment_set.iterrows(): dyna_temp = dyna_temp_original.format( int(row['n1']), int(row['n2']), int(row['n3']), int(row['n4']), float(row['mlc']) ) dyna_fh.write(dyna_temp) dyna_fh.write("*END\n") print("BOUNDARY_CONVECTION_SEGMENT.k file has been created successfully.") # # Export fringe result for visualize in LSPP # Define the template dyna_temp_original = """*ELEMENT_SHELL_THICKNESS $# eid pid n1 n2 n3 n4 n5 n6 n7 n8 {0},1,{1},{2},{3},{4} $# thic1 thic2 thic3 thic4 beta {5:.7g},{6:.7g},{7:.7g},{8:.7g},0.0\n""" # Open the file for writing with open("ELEMENT_SHELL_THICKNESS.k", "w") as dyna_fh: dyna_fh.write("*KEYWORD\n") # Iterate over each row in segment_set for index, row in segment_set.iterrows(): dyna_temp = dyna_temp_original.format( index+1, int(row['n1']), int(row['n2']), int(row['n3']), int(row['n4']), float(abs(row['mlc'])),float(abs(row['mlc'])),float(abs(row['mlc'])),float(abs(row['mlc'])) ) dyna_fh.write(dyna_temp) dyna_fh.write("*END\n") print("ELEMENT_SHELL_THICKNESS.k file has been created successfully.") # Plotting the data def plot_heat_transfer(data, title): x = data['x-coordinate'] y = data['y-coordinate'] z = data['z-coordinate'] heat_transfer_coef = data.iloc[:, -1] # Last column is heat transfer coefficient fig = plt.figure(figsize=(10, 8)) ax = fig.add_subplot(111, projection='3d') sc = ax.scatter(x, y, z, c=heat_transfer_coef, cmap='jet', marker='o') cbar = plt.colorbar(sc, ax=ax, shrink=0.5, aspect=10) cbar.set_label('Heat Transfer Coefficient') ax.set_xlim(0, 1) ax.set_ylim(0, 1) ax.set_zlim(0, 1) ax.set_xlabel('X-Coordinate') ax.set_ylabel('Y-Coordinate') ax.set_zlabel('Z-Coordinate') ax.set_title(f"{title} (Number of nodes: {len(data)})") ax.set_box_aspect([1, 1, 1]) ax.view_init(elev=35, azim=45) plt.show() plot_heat_transfer(Fluent_Convection, 'Fluent Convection Data') plot_heat_transfer(Nodes, 'LSDYNA Nodes Data')
1
