How to get the PyMechanical app.print_tree() into logger info.?
Naveen Kumar Begari
Naveen Kumar Begari Member Posts: 90
Hi team, Im trying to get the app.print_tree() tree data into the logger. Below is the script for you reference:
`import os
import logging
os.environ['PYTHONIOENCODING'] = 'utf8'
from ansys.mechanical.core import App
logger = logging.getLogger()
logger.setLevel(logging.DEBUG)
stream_handler = logging.StreamHandler(sys.stdout)
stream_handler.setLevel(logging.DEBUG)
logger.addHandler(stream_handler)
app = App()
app =App(version=242)
ansys_tree = ansys_app.print_tree()
logger.debug(f"Ansys Tree Structure:\n{ansys_tree }")
But Im unable to get the tree.
I need your assistance here..!!
  • Naveen Kumar Begari
    `import os
    import logging
    app = App()
    Take this as reference:
    `import os
    import logging
    app = App()
    ansys_tree = app.print_tree()
  • Landon Mitchell Kanner
    Hi @Naveen Kumar Begari . In your code, ansys_treeis not a string. There is probably a more elegant solution, but here's one workaround:
    tempfile = r'D:\temp.txt'
    import sys
    app = App()
    original_stdout = sys.stdout
    with open(tempfile, 'w', encoding="utf-8") as file:
       sys.stdout = file
       app.print_tree()
       sys.stdout = original_stdout
    with open(tempfile, encoding="utf-8") as file:
        ansys_tree = file.read()
    Hello @Landon Mitchell Kanner, Thank you so much for your response.
    But,
    when I execute these lines:
    ```python
    ansys_app = App(version=242)
    ansys_app.update_globals(globals())
    tempfile = 'simulation_logs.txt'
    with open(tempfile, 'a', encoding="utf-8") as file:
    sys.stdout = file
    ansys_trees = file.read()
    So in .txt file it was reading perfect but in webapp it was showing different.
    For you reference:
        sys.stdout = file
    What is your ultimate goal?
    @Landon Mitchell Kanner it's working fine, thanks for your support.
    from log file I need to show on the WebApp.
    @Landon Mitchell Kanner, While performing the analysis (specifically when the solver is triggered), the logger keeps disconnecting.
    Is there a way to keep it active on the web app?
    I am not very familiar with the logging module, which is part of Python and not developed by Ansys. What are you using to create a web app? I suggest you post a new question with enough details to reproduce the issue.
    Hi @Landon Mitchell Kanner, I'm using Dash technology for webapp development.
    Sure, I will post
