Contact settings issue? Or something else?
Hello, I am currently working on simulation a spine segment. The top and bottom ends of the L2 and L3 vertebral bodies are bonded to PMMA, and the faces in contact with the intervertebral disc are frictionless. As you can see, no load or deformation is ocurring in the bottom vertebral body, and I'm confused why. I have tried changing the settings of the faces in contact with the intervertebral disc from frictionless, to bonded, to frictional (0.1 coefficient of friction) with no luck. Can anyone help me out?
Hello @cort77 what is your scripting problem here? This forum is for scripting problems and coding issues etc. relating to Ansys products. If you don't have a coding problem then you might find more help over at the Ansys Learning Forum https://innovationspace.ansys.com/forum/
