How to export Animations from Mechanical in batch from WB script?
Rohith Patchigolla
I have a Modal analysis system with 100 deformations. I want to export all the animations in batch via WB scripting. All my deformations are grouped in a folder whose id can be used as an input to locate the result objects.
  • Rohith Patchigolla
    Here is an example script. You can run in from WB --> File --> Scripting --> Run Script File. You can track the time taken for each animation in the log file (WB --> Extensions --> View Log)
    #Example script to export animations
    mechScriptCmds = """
    ###User Inputs###
    import time
    #Get the right analysis to store the data
    UserAnimPath = DataModel.AnalysisList[0].WorkingDir
    GroupId=49
    Graphics.ResultAnimationOptions.NumberOfFrames=30
    Graphics.ResultAnimationOptions.Duration=Quantity(2,'sec')
    settings = Ansys.Mechanical.Graphics.AnimationExportSettings(width = 1920, height =1080)
    expFormat=GraphicsAnimationExportFormat.MP4
    Group=DataModel.GetObjectById(GroupId)
    for i in range(0,len(Group.Children)):
        begin = time.time()
        myResult=DataModel.GetObjectById(Group.Children[i].ObjectId)
        AnimPath=os.path.join(UserAnimPath,myResult.Name + ".mp4")
        ExtAPI.Log.WriteMessage(AnimPath)
        myResult.ExportAnimation(AnimPath,expFormat,settings)
        timetaken = time.time() - begin
        ExtAPI.Log.WriteMessage("Time taken for animation " + str(i+1) + " is :" + str(timetaken) + " s ")
    #Assuming we are working on 1st system in WB Project page
    #Get the right system to send the Mechanical script commands.
    mySys = GetAllSystems()[0]
    model = mySys.GetContainer(ComponentName="Model")
    model.Edit(Interactive=False)
    model.SendCommand(Language="Python", Command=mechScriptCmds)
    One can also do this export directly within Mechanical after the model solve is completed using Python Code object, with "After Post" callback. The script can be found below.
        Called after post processing.
        Keyword Arguments :
            solution -- Solution
        ###User Inputs###
        import time
        UserAnimPath="D:\\animation_data\\"
        GroupId=49
            begin = time.time()
            AnimPath=UserAnimPath+str(myResult.Name)+".mp4"
  • Chris Quan
    Chris Quan Member, Employee Posts: 2
    Second Anniversary First Comment Ansys Employee
    Rohith, thanks for the script. It is very useful.
