How to set up composite failure criteria and results
Erik Kostson
edited February 21 in Structures
Using mechanical scripting, how can we define composite failure criteria and composite failure results (using Composite Failure Tool inside mechanical)?
  • Erik Kostson
    edited February 21 Answer ✓
    Below is an example (max strain failure):
    # Create a new Composite Failure Criteria object
    composite_failure_criteria = Model.AddCompositeFailureCriteria()
    # Activate the Max Strain Failure Criterion
    composite_failure_criteria.MaximumStrain.Active = True
    #composite_failure_criteria.Puck.Active = True # for Puck fai.
    # Modify the Max Strain Failure Criterion settings
    composite_failure_criteria.MaximumStrain.EvaluateMaterialThreeDirectionFailure = True
    composite_failure_criteria.MaximumStrain.MaterialOneDirectionFailureWeightingFactor = 1.5
    composite_failure_criteria.MaximumStrain.TensileLimitMaterialOneDirection = 0.01
    #composite_failure_criteria.Puck.MatrixTensionFailureWeightingFactor = 1.2 # for Puck
    solution = Model.Analyses[0].Solution
    composite_failure_tool = solution.AddCompositeFailureTool()
    composite_failure_tool.Properties[3].InternalValue=2
    composite_failure_tool.Properties[4].InternalValue=composite_failure_criteria.ObjectId
    composite_failure_result = composite_failure_tool.AddInverseReserveFactor()
    For more info on all related methods and properties see here:
    https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/act_ref/Ansys_ACT_Automation_Mechanical_Results_CompositeFailureResults.html
