How can we automatically export far-field directivities from a harmonic acoustic analysis when performing a parametric study?
Below is one way of doing that (using python code object - after post). It assumes that we have a harmonic acoustic analysis with a results object called Far-field Maximum Scattered Pressure.
Script:
def after_post(this, solution):# Do not edit this line """ Called after post processing. Keyword Arguments : this -- the datamodel object instance of the python code object you are currently editing in the tree solution -- Solution """ # To access properties created using the Property Provider, please use the following command. # this.GetCustomPropertyByPath("your_property_group_name/your_property_name") # To access scoping properties use the following to access geometry scoping and named selection respectively: # this.GetCustomPropertyByPath("your_property_group_name/your_property_name/Geometry Selection") # this.GetCustomPropertyByPath("your_property_group_name/your_property_name/Named Selection") myfile='D:\maxprefarfield.txt' # change as needed ffr=ExtAPI.DataModel.GetObjectsByName('Far-field Maximum Scattered Pressure')[0] ffr.Activate() ffr.ExportToTextFile(myfile)
to get the current design point (say in order to include it in the saved file name use this:
import wbjn dpn=wbjn.ExecuteCommand(ExtAPI,"returnValue(a+Parameters.GetActiveDesignPoint().Name)",a="DP")
