How to get stress result (all points) from a path using scriptin in mechanical for every time step?
Rohith Patchigolla
  • Rohith Patchigolla
    The below script loops through all the result sets and exports the Path result for each result set as a csv in the directory specified. This is done for the first analysis in the tree (if not please adjust the analysis index in ResData accordingly).
    Also, this shows an example method of extracting a result object based on Name. if you have multiple result objects with same name, please check things carefully. The code will work well if result objects have unique names.
    import context_menu
    ResData = ExtAPI.DataModel.Project.Model.Analyses[0].GetResultsData()
    DataSets = ResData.ListTimeFreq
    fileDir = r"D:\del\"
    pathObj = DataModel.GetObjectsByName("Equivalent Stress")[0]
    for displayTime in DataSets:
        pathObj.Activate()
        pathObj.DisplayTime = Quantity(displayTime,"s")
        context_menu.DoRetrieveResults(ExtAPI)
        fileName = pathObj.Name + "_" + str(displayTime) + ".csv"
        filePath = os.path.join(fileDir,fileName)
        pathObj.ExportToTextFile(filePath)
