Write out Newton Raphson residual maximums
cobonz
cobonz Member Posts: 13
10 Comments First Anniversary
Hey togehter,
I have a simulation which takes about 500 iterations. It has about 500 contacts. I want to figure out the location the simulation has difficulties of convergence. Therefore, I would like to write out the coordinates of the max. of the newton Raphson residuum during the whole simulation into an csv. file.
Maybe also with MAPDL.
  • James Derrick
    James Derrick Administrator, Employee Posts: 391
    admin
    Hello @cobonz do you have any code that you've attempted to write already? How far did you get?
  • cobonz
    Hi James,
    I am not very educated with APDL code.
    I tried to use
    NLDIAG, EFLG, 1, 999
    I could also use
    NLDIAG, NRRE, 1, 999
    but there I do not really get any coordinates. I do not want to produce a lot of data.
  • Matthias
    Matthias Member Posts: 35
    10 Comments Name Dropper First Anniversary
    @cobonz
    If you are sure that the contact convergence is causing most of the issues you can look into the cnd-file. The default name is file.cnd.
    If you are using Ansys 2025R1 you can benfit from the cleaned up format of the file. The type of information you can find is (example from 2024R2 file):
    Contact Pair ID
    Number of Contact Elements in Contact
    Number of Contact Elements in Contact (Sticking)
    Max. Chattering Level
    Max. Penetration/Min. Gap
    Max. Geometric Gap
    Max. Normal Stiffness
    Min. Normal Stiffness
    Max. Resulting Pinball
    Max. Elastic Slip Distance
    Max. Tangential Stiffness
    Min. Tangential Stiffness
    Max. Sliding Distance of Entire Solution
    Max. Contact Pressure
    Max. Friction Stress
    Average Contact Depth
    Max. Geometric Penetration
    Number of Contact Points Have Too Much Penetration
    Contacting Area
    Max. Contact Damping Pressure
    Max. Contact Damping Tangential stress
    Max. Sliding Distance including near field
    Min. Sliding Distance including near field
    Max. normal fluid penetration pressure on contact surface
    Max. normal fluid penetration pressure on target surface
    Total volume loss due to wear on contact surface
    Total strain energy due to contact
    Frictional dissipation energy
    Contact damping dissipation energy
    WB contact pair ID
    Total contact force due to pressure -x component
    Total contact force due to pressure -y component
    Total contact force due to pressure -z component
    Total contact force due to tangential stress -x component
    Total contact force due to tangential stress -y component
    Total contact force due to tangential stress -z component
    Number of Contact Points Have Too Much sliding
    Contact pair force convergence norm
    Contact pair force criterion
    Max. tangential fluid penetration pressure on contact surface
    Max. tangential fluid penetration pressure on target surface
    Max. sliding distance of current substep for closed contact
    Amongst others there are
  • cobonz
    Hi Matthias,
    thanks that definitely helps. Though usually i have a lot of contacts (~400-800). Therefore, I would like to reduce the number I have to look at by putting out the location of trouble through Newton-Raphson maximums.
  • Matthias
    @cobonz
    Or you can look in the gst-file. GST = Graphical Solution Tracking. Unfortunately, the file format is not that user friendly for automated reading. Only one value per column is stored in each iteration.
    Time
    Load Step
    Sub-step
    Iter
    Time Incr
    Max DOF Incr
    Line Search Parameter
    Bisection
    F CRIT
    F L2
    U CRIT
    U INF
    Remesh
    Max Resi F
    Node with Max DOF Incr
    DOF with Max DOF Incr
    Node with Max Resi F
    DOF with Max Resi F
    Max Resi M
    Node with Max Resi M
    DOF with Max Resi M
    Of special interest for you would then be:
    F CRIT
    F L2
    Max Resi F
    DOF with Max Resi F
    You could for example then also calculate the ratio of "Max Resi F" to "F L2"
