Problem with installing PyAEDT
I am having trouble installing PyAEDT and get the following error message: "Error occurred configuring the PyAEDT panels" (see attached screenshot)
Thank you for your help!
  • svandenb-dev
    svandenb-dev Member, Employee Posts: 10
    10 Comments Second Anniversary Ansys Employee First Answer
    Hi @Andreas
    Maybe something were corrupted by multiple installation. I would suggest deleting the python venv created by the script and install again.
    in your windows explorer bar type %APPDATA% which will redirect to your AppData\roaming folder.
    Then delete the .pyaedt_env folder and run again the installation script.
    I hope it helps.
