How to generate parametric geometry in Discovery using scripting?
Erik Kostson
edited March 4 in 3D Design
Is it possible to generate parametric geometry in Discovery using scripting, and is there an example?
  • Erik Kostson
    edited March 4 Answer ✓
    Yes it is.
    Below is a simple example of a cylindrical shell with radius = Rad (parameter), and height = Hei (parameter).
    First open the script editor inside Discovery, and activate Embed Script (slide nr 10 / step1: see link below). After that we get the parameter icon (slide nr 10 / step 3).
    https://innovationspace.ansys.com/courses/courses/scripting-in-ansys-discovery/lessons/parameters-lesson-5/
    As shown in the above link, define the 2 parameters needed for the below script (Rad, and Hei).
    In the script editor paste the below script, and run it in order to generate the geometry:
    r=Parameters.Rad
    h=Parameters.Hei
    sectionPlane = Plane.PlaneXY
    result = ViewHelper.SetSketchPlane(sectionPlane, None)
    origin = Point2D.Create(M(0), M(0))
    results = SketchCircle.Create(origin, M(r))
    mode = InteractionMode.Section
    result = ViewHelper.SetViewMode(mode, None)
    selection = Selection.Create(GetRootPart().DatumPlanes[0].Curves[0])
    options = ExtrudeEdgeOptions()
    result3 = ExtrudeEdges.Execute(selection,M(h), options)
    GetRootPart().DatumPlanes[0].Delete()
    mode = InteractionMode.Solid
    selected_body =  Selection.Create(GetRootPart().Bodies[0])
    secondarySelection = Selection.Empty()
    # Create a new named selection group with the selected faces
    result = NamedSelection.Create(selected_body, secondarySelection, "Mysel")
