How can we export the Acoustic AWeightedSPL FR result data using mechanical scripting?
Erik Kostson
edited March 5 in Structures
We want to first add an Acoustic A-Weighted SPL frequency response (FR) result, and then export/print the result data using mechanical scripting?
Best Answers
  • Erik Kostson
    edited March 6 Answer ✓
    It can be done in the following way (as the ExportToTextFile method is missing for this result object):
    model=ExtAPI.DataModel.Project.Model # refer to Model
    analysis = model.Analyses[0]
    solution=analysis.Solution
    ns=ExtAPI.DataModel.GetObjectsByName('Open Domain')[0]
    res=solution.AddAcousticAWeightedSPLFrequencyResponse()
    res.Location=ns
    res.EvaluateAllResults()
    res.Activate()
    paneTabular=ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.TabularData)
    control = paneTabular.ControlUnknown
    for col in range(1,control.ColumnsCount+1):
        for row in range(1,control.RowsCount+1):
            cellText= control.cell(row ,col ).Text
            if cellText!=None:
                print cellText
  • Erik Kostson
    edited March 5 Answer ✓
    If the result exists and the resulting data is there, then we need to activate the result object first before using the paneTabular function:
    rs=ExtAPI.DataModel.GetObjectsByName('Frequency Response')[0]
    rs.Activate()
            if cellText!=None:
                print cellText
