How to change the default timeout in pyoptislang?
Georg Kandler
Georg Kandler Member, Employee Posts: 10
Second Anniversary Ansys Employee Solution Developer Community of Practice Member Name Dropper
The default timeout for pyoptislang is 30 seconds, which can be too short for certain operations.
Is it possible to change the default timeout value?
  • Georg Kandler
    You can access and change the default timeout value by running the following command:
    osl = Optislang()  # create the oSL instance
    osl.osl_server.timeouts_register.default_value = 600.0  # Change the default value to 600 seconds
