How to execute scheme commands by UDF
In the Fluent console, we can define a variable which contains the scheme command to execute. The value of this variable can be updated by UDF. Then the command can be applied with a calculation activity.
To define the variable, type the following command in the Fluent console. In the example below, the variable is called 'mycommand'.
(rp-var-define 'mycommand "" 'string #f)
The value of the variable can be updated by UDF with the macro RP_Set_String. In the example below, the value of the variable is set to "/solve/set/time-step 2.5".
#include "udf.h" DEFINE_ON_DEMAND(update_mycommand) { RP_Set_String("mycommand", "/solve/set/time-step 2.5"); Message0("\n\n UDF DONE \n\n"); }
In the calculation activities, we can define an execute command with the command below.
(ti-menu-load-string (%rpgetvar 'mycommand))
