How can we write some tabular result data to a file , where each result type is next to each other?
Erik Kostson
edited March 11 in Structures
Say we have several different result objects and each of them are time dependent. We want to write some tabular result data to a file. Each result object results data should come next to each other, so if we have 4 columns per results object and 2 result objects (say displacement and stress), then the second stress result object should start at the position highlighted below. So the written data will be following the below pattern.
Best Answers
  • Erik Kostson
    edited March 11 Answer ✓
    One possible way of doing this is shown in the sample script below:
    ResultsOfIn = []
    ResultsOfIn.append('Directional Deformation')
    ResultsOfIn.append('Equivalent Stress')
    myd=''
    results = DataModel.GetObjectsByType(DataModelObjectCategory.Result)
    res = DataModel.GetObjectsByName(ResultsOfInterest[0]) [0]
    res.Activate()
    Pane=ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.TabularData)
    Con = Pane.ControlUnknown
    rows=Con.RowsCount
    with open('D:\mycsvfile2.csv', 'a') as file:
        for R in range(0,rows,1):
            print(R)
            for ires in ResultsOfIn:
                res = DataModel.GetObjectsByName(ires) [0]
                res.Activate()
                for C in range(2,Con.ColumnsCount+1):
                    myd=str(myd)+ ','+(Con.cell(R+1,C).Text)
            file.write(myd+'\n')
            myd=''
  • Rohith Patchigolla
    another possible solution...
    ##### INPUTS #####
    #region Importing modules:
    import csv
    import wbjn
    #endregion
    ResultsOfInterest = []
    ResultsOfInterest.append('Directional Deformation')
    ResultsOfInterest.append('Equivalent Stress')
    ResultsOfInterest.append('Equivalent Stress 2')
    ##### EXECUTION #####
    def writeCSV(filename, data):
       # Function to write python list to a csv file
       with open(filename, 'wb') as csvfile:
           spamwriter = csv.writer(csvfile, delimiter=',', quotechar='|', quoting=csv.QUOTE_MINIMAL)
           for row in data:
               spamwriter.writerow(row)
    cmd = 'returnValue(GetUserFilesDirectory())'
    user_dir = wbjn.ExecuteCommand(ExtAPI, cmd)
    AnalysisNumber=0
    data=[]
    column=0
    for i in ResultsOfInterest:
        res = DataModel.GetObjectsByName(i) [0]
        res.Activate()
        for R in range(1,Con.RowsCount+1):
            data.append([])
                data[-1].append(Con.cell(R,C).Text)
    # Step 1: Find indices where new datasets start
    dataset_indices = [i for i, row in enumerate(data) if row[0] == "Time [s]"]
    dataset_indices.append(len(data))  # Add end index for last dataset
    # Step 2: Extract all datasets
    datasets = [data[start:end] for start, end in zip(dataset_indices, dataset_indices[1:])]
    # Step 3: Merge datasets column-wise
    merged_data = [sum([ds[0] for ds in datasets], [])]  # Merge headers
    for rows in zip(*[ds[1:] for ds in datasets]):  # Merge data rows
        merged_data.append(sum(rows, []))
    writeCSV(user_dir + "/" + Model.Analyses[AnalysisNumber].Name + " - " + ".csv", data)
    writeCSV(user_dir + "/" + Model.Analyses[AnalysisNumber].Name + " - 2" + ".csv", merged_data)
    print("Script has completed!")
    print("")
    print("Open File: " + chr(34) + user_dir + chr(92) + Model.Analyses[AnalysisNumber].Name + " - " + ".csv" + chr(34))
