How Does the Fill Command Create a Face, and How do I Delete Them?
Background
Over the last month, I have tried to answer my own question and just can't. What I could really use help with is directions or resources to fix the issue that exists.
The Problem
I have a complex geometry where many (approximately 300) odd shaped pores exist inside of 10mm circle and outside of a smaller circle of 3.5mm. My goal is to fill the whole area inside of the circle and then delete the faces inside those odd shapes. So far, all I can figure out is...
*select using a polygon which looks like,
selection=Selection.Create(Curve26,Curve...,
I think then I would merge faces with the outside circle and those faces already filled and use select and facets to delete? Please see my example code for a far simpler example where I do just this.
The issue I run into with this is, because it is really complex and filled with tons of shapes, it is hard to merge everything well.
I feel like the easiest way would be to sequentially create faces, merge them, and then delete only the relevant ones.
If anyone could help, that would be awesome. I really need to scale a solution to this larger problem.
Example Code
# Sketch Circle origin = Point2D.Create(MM(0), MM(0)) result = SketchCircle.Create(origin, MM(5.3851648071345)) baseSel = SelectionPoint.Create(CurvePoint35) targetSel = SelectionPoint.Create(DatumLine2) result = Constraint.CreateCoincident(baseSel, targetSel) baseSel = SelectionPoint.Create(CurvePoint35) targetSel = SelectionPoint.Create(DatumLine3) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Circle origin = Point2D.Create(MM(0), MM(0)) result = SketchCircle.Create(origin, MM(20.6155281280883)) baseSel = SelectionPoint.Create(CurvePoint36) targetSel = SelectionPoint.Create(DatumPoint2) result = Constraint.CreateCoincident(baseSel, targetSel) baseSel = Curve19 targetSel = Curve20 result = Constraint.CreateConcentric(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(-13), MM(11)) end = Point2D.Create(MM(-13), MM(7)) result = SketchLine.Create(start, end) curveSelList = Curve21 result = Constraint.CreateVertical(curveSelList) # EndBlock # Sketch Line start = Point2D.Create(MM(-13), MM(7)) end = Point2D.Create(MM(-5), MM(7)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint37) targetSel = SelectionPoint.Create(CurvePoint38) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(-5), MM(7)) end = Point2D.Create(MM(-4), MM(10.7320508075689)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint39) targetSel = SelectionPoint.Create(CurvePoint40) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(-4), MM(10.7320508075689)) end = Point2D.Create(MM(-13), MM(11)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint41) targetSel = SelectionPoint.Create(CurvePoint42) result = Constraint.CreateCoincident(baseSel, targetSel) baseSel = SelectionPoint.Create(CurvePoint43) targetSel = SelectionPoint.Create(CurvePoint44) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(10), MM(11)) end = Point2D.Create(MM(6.53589838486224), MM(5)) result = SketchLine.Create(start, end) # EndBlock # Sketch Line start = Point2D.Create(MM(6.53589838486224), MM(5)) end = Point2D.Create(MM(14), MM(3)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint45) targetSel = SelectionPoint.Create(CurvePoint46) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(14), MM(3)) end = Point2D.Create(MM(14), MM(8)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint47) targetSel = SelectionPoint.Create(CurvePoint48) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(14), MM(8)) end = Point2D.Create(MM(10), MM(11)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint49) targetSel = SelectionPoint.Create(CurvePoint50) result = Constraint.CreateCoincident(baseSel, targetSel) baseSel = SelectionPoint.Create(CurvePoint51) targetSel = SelectionPoint.Create(CurvePoint52) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(9), MM(-4)) end = Point2D.Create(MM(6), MM(-11)) result = SketchLine.Create(start, end) # EndBlock # Sketch Line start = Point2D.Create(MM(6), MM(-11)) end = Point2D.Create(MM(15), MM(-9)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint53) targetSel = SelectionPoint.Create(CurvePoint54) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(15), MM(-9)) end = Point2D.Create(MM(16.2589844124411), MM(-5)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint55) targetSel = SelectionPoint.Create(CurvePoint56) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(16.2589844124411), MM(-5)) end = Point2D.Create(MM(9), MM(-4)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint57) targetSel = SelectionPoint.Create(CurvePoint58) result = Constraint.CreateCoincident(baseSel, targetSel) baseSel = SelectionPoint.Create(CurvePoint59) targetSel = SelectionPoint.Create(CurvePoint60) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(-11), MM(-3)) end = Point2D.Create(MM(-12), MM(-9)) result = SketchLine.Create(start, end) # EndBlock # Sketch Line start = Point2D.Create(MM(-12), MM(-9)) end = Point2D.Create(MM(-5), MM(-12.1845262184354)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint61) targetSel = SelectionPoint.Create(CurvePoint62) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(-5), MM(-12.1845262184354)) end = Point2D.Create(MM(-5), MM(-5)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint63) targetSel = SelectionPoint.Create(CurvePoint64) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Sketch Line start = Point2D.Create(MM(-5), MM(-5)) end = Point2D.Create(MM(-11), MM(-3)) result = SketchLine.Create(start, end) baseSel = SelectionPoint.Create(CurvePoint65) targetSel = SelectionPoint.Create(CurvePoint66) result = Constraint.CreateCoincident(baseSel, targetSel) baseSel = SelectionPoint.Create(CurvePoint67) targetSel = SelectionPoint.Create(CurvePoint68) result = Constraint.CreateCoincident(baseSel, targetSel) # EndBlock # Fill selection = Curve20 secondarySelection = Selection.Empty() options = FillOptions() result = Fill.Execute(selection, secondarySelection, options, FillMode.Layout, Info10) # EndBlock # Fill selection = Selection.Create(Curve21, Curve22, Curve23, Curve24, Curve25, Curve26, Curve27, Curve28, Curve29, Curve30, Curve31, Curve32, Curve33, Curve34, Curve35, Curve36) secondarySelection = Selection.Empty() options = FillOptions() result = Fill.Execute(selection, secondarySelection, options, FillMode.Layout, Info11) # EndBlock # Fill selection = Curve19 secondarySelection = Selection.Empty() options = FillOptions() result = Fill.Execute(selection, secondarySelection, options, FillMode.Layout, Info12) # EndBlock # Solidify Sketch mode = InteractionMode.Solid result = ViewHelper.SetViewMode(mode, Info13) # EndBlock # Create New Face selection = Face1 result = ReplaceFacesWithFace.Execute(selection) # EndBlock # Delete Selection selection = Face3 result = Delete.Execute(selection) # EndBlock # Delete Selection selection = Face4 result = Delete.Execute(selection) # EndBlock # Delete Selection selection = Face5 result = Delete.Execute(selection) # EndBlock # Delete Selection selection = Face2 result = Delete.Execute(selection) # EndBlock # Set Sketch Plane sectionPlane = Plane.PlaneXY result = ViewHelper.SetSketchPlane(sectionPlane, Info14) # EndBlock
Hello needhelp,
A couple of things here: I recommend using Index Variables instead of Intelligent Variables as it gives you better reproducibility. When I try to follow your code, I don't have a CurvePoint35 for example.
Sorry I did not see your replies in the reqest here: https://discuss.ansys.com/discussion/4690/help-with-fill-command . It doesn’t appear that the forum sends emails out when someone replies to a topic (or the email blocks them, they aren’t in SPAM). The approach I used there was to grab all the faces on one plane. Using a loop, I then compare the Bounding Box of each of the faces. Of course, the Bounding Box of the outer face will be larger than that of an inner face and this is the test that is used in the findOuter routine.
If you need direct help, you should be able to find my contact information at the following webpage: https://www.tu-chemnitz.de/chemie/tech/mitarbeiter.php
- Nick F. L.
Create your sketch on a plane. Then you should be able to run the following to create a Surface Body.
``` # Python Script, API Version = V23
Fills between all the curves, everything in at one surface body
selection = Selection.Create(GetRootPart().DatumPlanes[-1].Curves[:])
options.AutoExtendFillArea = False
options.PatchBlend = False
options.ZipLaminarEdges = False
options.GapAngle = DEG(10)
options.GapDistance = MM(0.1)
options.UntrimSingleFace = True
options.AllowMultiFacePatch = False
result = Fill.Execute(selection, secondarySelection, options, FillMode.Layout, None)EndBlock
This Keeps your Sketch
selection = Selection.Create(GetRootPart().DatumPlanes[0].GetChildrenIDocObject[-1])
result = SketchHelper.SetSketchLayout(selection, True)EndBlock
Returns to 3D mode
result = ViewHelper.SetViewMode(mode, None)EndBlock
