Difference in average stress values between Mechanical and ACT
Pernelle Marone-Hitz
The averaged Von Mises and principal stress results from Mechanical UI are different to the averaged Von Mises and principal stress values obtained through ACT with stress = reader.GetResult("PRIN_S") and ResultAveragingEnum.Average option, why is that?
This is due to the order in which the following operations are performed:
- calculating Von Mises and principal stresses
- averaging the values.
Further explanations can be found here:
- https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/wb_sim/ds_Unaveraged_Results.html?q=average
- https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_cmd/Hlp_C_AVPRIN.html
In Mechanical, we:
- Average the component (X, Y, Z, XY, YZ, XZ) stress values from the elements at a common node.
- Calculate the Von Mises stress (or principal stresses) from the averaged component values. This is similar to using AVPRIN,0 in Mechanical APDL.
Through ACT scripting, with stress = reader.GetResult("PRIN_S"), we:
- Calculate the unaveraged principal and Von Mises stresses
- Average the values if user selects ResultAveragingEnum.Average option in the custom result. This is similar to using AVPRIN,1 in Mechanical APDL.
2
