Hi team,
Is it possible to scope surface elements SURF154 by PyDPF? Note the surface elements have been defined by APDL Snippet prior solution. Following code returns just one element type in my case - SHELL181. SURF154 is missing.
dataSources = dpf.DataSources(analysis.ResultFileName)
model = dpf.Model(dataSources)
mesh = model.Mesh
apdl_et = mesh.GetPropertyField('apdl_element_type')
apdl_et_list = set(apdl_et.Data)
print(apdl_et_list)
On the other hand, if ACT reader is used, both element types are present. I am also able to get a list of their element Ids.
analysis = model.Analyses[0]
reader = analysis.GetResultsData()
mesh = reader.CreateMeshData()
elem_ids = mesh.ElementIds
results = reader.GetResult('PNUM')
results.SelectComponents(['ENAM'])
elem_names = set([results.GetElementValues(elem_id) for elem_id in elem_ids])
print(elem_names)
surf_ids = [elem_ids[index] for index, elem_name in enumerate(elem_names) if elem_name[0] == 154]
surf_ids.sort()
reader.Dispose()
Could be the list of surface element Ids used in some way for getting a contour of applied on load on these elements by Python Result?
Thank you for any hint.
