Accessing "Contact Real Constant" via python
Dominique_Cracovia
Member Posts: 7
Is there any way to access and/or export a Contact's Real Constant value?
I know I can export manually an Initial Contact Information object, but could I access this Worksheet with python / JS?
I would like to filter Contracts by type and then read a Contact's Real Constant.
Hi @Dominique_Cracovia thanks for your question! @Structures-Scripting-Team should be able to assist you here.
Use this part of the API. You can get the contact and target side Ids and the real constant should be equal to one of them. I forget off hand which one, but check the input file and you can see.
