How to set the details of Solution Combination sheet with scripting?
Sean988
Sean988 Member Posts: 2 **
I need to use fatigue tool in ACT scripting, but I can't find the API to set the value of the Solution Combination sheet. like Time/Frequency data, combination factor
  • James Derrick
    James Derrick Administrator, Employee Posts: 357
    admin
    Hi @Sean988 Thanks for the question! I think you're after PyMechanical advice, is that correct? Or ACT advice? If you can provide some more information on where you've already looked and what you've tried, that will help a lot. Otherwise, I'll see if the @Structures-Scripting-Team can help.
  • akshays
    akshays Member, Employee Posts: 1
    edited May 27
    You can use the following script to automate Solution Combination worksheet:
    SCom = ExtAPI.DataModel.Project.Model.AddSolutionCombination()
    SCom.AddDirectionalDeformation()
    stat = ExtAPI.DataModel.Project.Model.Analyses[0]
    stat2 = ExtAPI.DataModel.Project.Model.Analyses[1]
    name = stat.Name
    name2 = stat2.Name
    #select analysis for combination
    SCom.Definition.SetBaseCaseAnalysis(0,stat)
    #add base case and select the analysis
    SCom.Definition.AddBaseCase(str(name2),stat2,1)
    SCom.Definition.SetBaseCaseTime(0,1)
    #set combination coefficients
    SCom.Definition.SetCoefficient(0,0,1)
    SCom.Definition.SetCoefficient(0,1,1)
    More details can be found here:
    https://ansyshelp.ansys.com/public/account/secured?returnurl=////Views/Secured/corp/v251/en/act_script/act_script_examples_solution_combinations.html?q=AddSolutionCombination
