How to import materials from a .xml file? There is no detail in the help document
Hi @Sean988 thanks for the question! Can you provide a bit more detail about your problem? In particular it would be useful to know which product you're working with and which Python library you're trying to write a script for. Additionally, if you could share anything that you've already tried that would be very helpful.
In addition to @James Derrick comments, I'd suggest that you use the recording from the WB project page, it should give you the commands of what you are tying to do.
