PyAnsys Geometry: Issues with Share Topology
Hi everyone,
I’m using PyAnsys Geometry to create a rectangular tube for a CFD simulation in Fluent. After building the 3D model and naming the solid and fluid zones, I have a question about how to properly set Share Topology - Share. I tried using "Design.set_shared_topology" and "Component.set_shared_topology", but neither of these worked.
I’ve attached my code and some screenshots below.
Additionally, I previously posted a thread about extracting volume:
https://innovationspace.ansys.com/forum/forums/topic/trouble-extracting-fluid-volume-in-pyansys-geometry-for-cfd-setup/
I tried the first method Atharv mentioned, but I still couldn’t extract the volume using "PrepareTools.extract_volume_from_faces(sealing_faces, inside_faces)". That’s why I ended up using a boolean operation in the code above.
Any insight or advice regarding volume extraction, setting shared topology, or suppressing the lid for physics would be much appreciated!
Hi @Akiasa
Can you add the following in your script
from ansys.geometry.core.designer import SharedTopologyType ### Define Share Topology between bodies in the component component.set_shared_topology(share_type=SharedTopologyType.SHARETYPE_SHARE)
