Plot of field lines in Ansys Maxwell (2D Electrostatic)
Lucie
Member Posts: 3
I would like to plot the field lines on of the surface of my system. After making the Analyze, I tried to plot lines with this :
app = Maxwell2d() # Get face IDs of the air block face_ids = app.modeler.get_object_faces("AirBloc") oModule = oDesign.GetModule("FieldsReporter") seeding_faces_str = str(seeding_faces[0]) oModule.CreateFieldPlot( [ "NAME:FieldLineTrace_Plot1", "SolutionName:=" , "Setup1 : LastAdaptive", "UserSpecifyName:=" , 0, "UserSpecifyFolder:=" , 0, "QuantityName:=" , "QuantityName_FieldLineTrace", "PlotFolder:=" , "Field line trace plot", "IntrinsicVar:=" , "", "Trace Step Length:=" , "0.001mm", "Use Adaptive Step:=" , True, "Seeding Faces:=" , f"[1,{seeding_faces_str}]", "Seeding Markers:=" , [0], "Surface Tracing Objects:=", [0], "Volume Tracing Objects:=", f"[1,{seeding_faces_str}]", "Seeding Sampling Option:=", True, "Seeding Points Number:=", 100, "Fractional of Maximal:=", 0.2, "Discrete Seeds Option:=", "Maximal Field Point", [ "NAME:InceptionEvaluationSettings", "Gas Type:=" , 0, "Gas Pressure:=" , 1, "Use Inception:=" , True, "Potential U0:=" , 0, "Potential K:=" , 0, "Potential A:=" , 1 ], [ "NAME:FieldLineTracePlotSettings", [ "NAME:LineSettingsID", "Width:=" , 1, "Style:=" , "Solid" ], "IsoValType:=" , "Tone" ] ], "FieldLineTrace")
But, I get an message on Ansys that said the plot have been removed because of a geometry/Value change :
[warning] Plot 'FieldLineTrace_Plot1' has been removed due to deletion of quantity expression.
When you create the plot, is that object stored in a variable somewhere? Perhaps it is being stored as a local variable that is being lost when context moves outside of the function the plot happens in?
I think the problem simply came from the type of the surface number I was calling — I was retrieving it as a string, but the function was expecting an integer. Thank you for the Help
