Each time step in an RST file may have a different value of OMEGA that was used. I believe this information is available in the RST, is it possible to get the values using DPF
Hey @Jim Kosloski I don't know but the @Structures-Scripting-Team might
@Jim Kosloski OMEAGA you mean is rpm value, right? If so, you can get rpm value from TimeFreqSupport.rpms
https://dpf.docs.pyansys.com/version/stable/api/ansys/dpf/core/time_freq_support/TimeFreqSupport.html#TimeFreqSupport.rpms
@Ryoma thanks for the information. That seems like it should be the answer, but it does not work. It does not return anything for a model that has OMEGA applied. Besides not working, there are a few issues with this anyway:
@Jim Kosloski , @Ryoma , These concepts are very easy to confuse, but there are distinct things for different workflows being discussed.
You can see in the old post for what's new in mechanical ~V19, Mechanical started to support multi-RPM harmonic analysis in support of electric motor design (mostly). This allows you to setup multiple harmonic analysis steps, with a specified RPM, and do a freq. sweep at each RPM. Each RPM has a freq. range defined for it. Effectively you are doing multiple harmonic sweeps in a single harmonic analysis. The DPF operator is getting that RPM value, and the RPM terminology is correct and consistent.
What the original question is really about is a LOAD value that is an angular velocity. This is not an RPM time point, but a rotational speed applied as a body load on elements. There are a few commands and ways to apply this load, and it can be applied to all or some of the elements, or there can also be different rotational speeds for different elements (think two rotors spinning at different speeds). The rotational speed can also be synced (via SYNCHRO command) to the harmonic excitation freq. and a factor (default=1) can be used. This is typical in rotordyamics where the excitation is a mass unbalance that is a 1x excitation. As pointed out by Jim, rotational speed as a load is also a vector with 3 components, so you can theoretically have 3 values per element for any given substep.
To the original question, I do not think there is a published way in DPF to extract the load value of a rotational velocity. I am not even sure there is a good way to do this with APDL commands at current time, but if you know of an APDL way please share. In a PyAnsys domain, you could then use PyMAPDL to get the values instead of PyDPF.
https://storage.ansys.com/mbu-assets/Mech/whatsnew/WhatsNew193.htm
I was going through my old posts and noticed that this was never answered here. I did find a way to do this, but using pyMAPDL rather than pyDPF. See this script:from ansys.mapdl.core import launch_mapdl mapdl = launch_mapdl() xpl = mapdl.xpl
rstName = r"D:\jkoslosk\Applications\DPF\omegatest_files\dp0\SYS\MECH\file.rst" setNum = 1 # Enter the results set number to get the OMEGA values from
xpl.open(rstName) vecHead=xpl.read('HEADER',asarray=True) nlg = vecHead[34]
setStr = "DSI::SET" + str(setNum) str = xpl.step(setStr) vec=xpl.read('dphead',asarray=True) omegax=vec[13] omegay=vec[14] omegaz=vec[15] cgomgax=vec[19] cgomgay=vec[20] cgomgaz=vec[21]
