Coupled Field Transient - Friction Stir Processing HELP
organicCow224
organicCow224 Member Posts: 1 **
Hi all.
I am currently trying to simulate Friction Stir Deposition using coupled field transient, where the geometry consists of a consumable rod and a plate (substrate). This rod is to then rotate at a given RPM and with a certain loading and traverse at a certain speed in the desired direction.
Both are made of 304 stainless steel and I have declared material properties taking the FS welding sample file from the ANSYS help website.
The stages of the process are:
stage 1: the tool plunges into the workpiece/baseplate. (end time 1 sec)
stage 2: the tool spins in one place for a few seconds at a given rpm. (dwell) (end time 6 sec)
stage 3: the tool advances with a certain travel speed while rotating at my given rpm. (traverse) (end time 156 sec)
The boundary conditions I have set are:
1. rotational velocity: I have given 83 rad/s rotational velocity to the tool.
2. remote force: I have applied 10000N of force on the top surface of the tool.
3. fixed support: the bottom and sides of the workpiece were constrained as fixed supports.
4. convection: All surfaces were given some convection coefficient (30).
5. remote displacement: in the third stage the tool moves 0.1 m in the desired direction.
6. plastic heating: since both the tool and the workpiece get plastically deformed here I have enabled plastic heating with a work fraction of 0.8
7. meshing: for the baseplate I have given multizone meshing with no other modifications and for the tool I have given Sweep meshing with no other modifications.
8. frictional contact: the bottom face of the tool and the top face of the plate are having frictional contact with coefficient 0.4
problems I am facing:
1. position and ends up getting compressed without rotating.
The temperature does not vary at all. It stays at the ambient 35C.
2. while setting the "contacts" the label still says "frictional - No selection to No selection" even though I selected the bottom face of the tool and the top face of the workpiece. on trying again it now says "invalid contact region"
I am also getting some errors/warnings like:
"One or more contact pairs are detected with a friction value greater than 0.2. If convergence problems arise, switching to an unsymmetric Newton Raphson option may aid in convergence."
"One or more MPC or Lagrange Multiplier formulation based contact regions or remote boundary conditions may have conflicts with other applied boundary conditions or other contact or symmetry regions. This may reduce solution accuracy. For MPC based remote points, setting the relaxation method may help eliminate overconstraint. Tip: You may graphically display FE Connections from the Solution Information Object for non-cyclic analysis. Refer to Troubleshooting in the Help System for more details."
I am solving for temperature at each stage, stress and strain. What I am looking for is to get a good picture of the variations in these parameters and also to show the plastic deformation and/or deformation on both the tool and workpiece.
Can someone help me out here?
PS: I haven't given any commands using APDL because I am not familiar with it. Once I get a clean solve I will also want to integrate a command to vary the friction coefficient with temperature.
Best
