I need to plot difference in results between two models, with same geometry but different mesh.
The following code maps results from the coarser mesh to the finer mesh and then plots differences between the mapped and real results on the finer mesh.
from ansys.dpf import core as dpf from ansys.dpf.core.plotter import DpfPlotter map_to = r"\Path \to\model1\file.rst" map_from = r"\Path \to\model2\file.rst" model_from = dpf.Model(map_from) ds_from = dpf.DataSources(map_from) model_to = dpf.Model(map_to) mesh_from = model_from.metadata.meshed_region mesh_to = model_to.metadata.meshed_region sx_from_op = dpf.operators.result.stress_X(data_sources=ds_from) sx_from = sx_from_op.outputs.fields_container.get_data() # Map to mapped_res_op = dpf.operators.mapping.on_coordinates(fields_container=sx_from, coordinates=mesh_to.nodes.coordinates_field) mapped_res = mapped_res_op.outputs.fields_container.get_data() plot = DpfPlotter() # Create a new mesh and translate it along the x axis. mesh_new_from = mesh_from.deep_copy() overall_field = dpf.fields_factory.create_3d_vector_field(1, dpf.locations.overall) overall_field.append([50.0, 0.0, 0.0], 1) # Translate by 50.0mm coordinates_to_update = mesh_new_from.nodes.coordinates_field add_operator = dpf.operators.math.add(coordinates_to_update, overall_field) coordinates_updated = add_operator.outputs.field() coordinates_to_update.data = coordinates_updated.data # Calculate Delta ds_to = dpf.DataSources(map_to) targ_res_sx_op = dpf.operators.result.stress_X(data_sources=ds_to) targ_res_sx = targ_res_sx_op.outputs.fields_container.get_data() field_lc1 = targ_res_sx[0] field_lc2 = mapped_res[0] # Scale LC2 to -1. field_lc2_sc = dpf.operators.math.scale(field=field_lc2, weights=-1.0) # Delta delta_op = dpf.operators.math.add(fieldA=field_lc1, fieldB=field_lc2_sc) delta = delta_op.outputs.field.get_data() # Plot Delta results plot.add_field( delta, meshed_region=mesh_to ) plot.show_figure()
