How to calculate volume of elements whose stresses are above a given value (e.g. 100MPa)?
Javier Vique
Javier Vique Member, Employee Posts: 93
I would like to identify elements whose stresses are above 100MPa and calculate their volume, calculating afterwards the percentage against total volume.
  • Javier Vique
    For this exercise, we will assume that it is ok to get stresses at centroid. Based on this assumption, this would be the code using dpf:
    import mech_dpf
    mech_dpf.setExtAPI(ExtAPI)
    model = dpf.Model(dataSource)
    op_seqv = dpf.operators.result.stress_eqv_as_mechanical()
    op_seqv.inputs.data_sources.Connect(dataSource)
    op_seqv.inputs.requested_location.Connect(dpf.locations.elemental)
    seqv = op_seqv.outputs.fields_container.GetData()
    MyThreshold = 100
    op_hp = dpf.operators.filter.field_high_pass_fc()
    op_hp.inputs.fields_container.Connect(seqv)
    op_hp.inputs.threshold.Connect(MyThreshold)
    seqv_h = op_hp.outputs.fields_container.GetData()
    op_v = dpf.operators.result.elemental_volume()
    op_v.inputs.data_sources.Connect(dataSource)
    v_fc = op_v.outputs.fields_container.GetData()
    op_tv = dpf.operators.math.accumulate()
    op_tv.inputs.fieldA.Connect(v_fc[0])
    tv_fc = op_tv.outputs.field.GetData()
    total_vol = tv_fc.Data[0]
    op_r = dpf.operators.scoping.rescope_fc()
    op_r.inputs.fields_container.Connect(v_fc)
    op_r.inputs.mesh_scoping.Connect(seqv_h[0].Scoping)
    v_fc_100 = op_r.outputs.fields_container.GetData()
    op_v100 = dpf.operators.math.accumulate()
    op_v100.inputs.fieldA.Connect(v_fc_100[0])
    v100_fc = op_v100.outputs.field.GetData()
    vol100 = v100_fc.Data[0]
    print('% above 100MPa : ' + str(vol100/total_vol*100))
