Hi @yuelei fu thanks for your question! Can you elaborate a bit on what you're after, as well as any documentation you've already checked and any code you've already tried?
@James Derrick , I want to export different contour's 3D image, So I need to switch between different types of contours. Before that I checked Discovery API V251 about Contour class, however can't find the method.
