Hello everyone,
I am trying to run the example "HDF5 export and import operations" however, when running the line:
h5_read_op = dpf.operators.result.result_provider()
i get the error:
AttributeError: module 'ansys.dpf.core.operators.result' has no attribute 'result_provider'
Ichecked online and it seems like results_provider should be part of dpf.operators.result however it does not seem to be the case in my dpf installation. I tested in two machines and I get the same error in both.
my python version is 3.11 and my package versions are:
ansys-acp-core 0.1b2
ansys-additive-core 0.18.1
ansys-additive-widgets 0.2.1
ansys-api-acp 0.1.0.dev9
ansys-api-additive 1.7.2
ansys-api-dbu 0.3.4
ansys-api-dyna 0.3.6
ansys-api-edb 1.0.10
ansys-api-fluent 0.3.31
ansys-api-geometry 0.4.6
ansys-api-mapdl 0.5.2
ansys-api-mechanical 0.1.2
ansys-api-meshing-prime 0.1.3
ansys-api-modelcenter 0.3.1
ansys-api-platform-instancemanagement 1.1.0
ansys-api-pyensight 0.4.1
ansys-api-sherlock 0.1.27
ansys-api-systemcoupling 0.1.0
ansys-api-tools-filetransfer 0.1.1
ansys-api-workbench 0.2.0
ansys-conceptev-core 0.1.4
ansys-dpf-composites 0.5.0
ansys-dpf-core 0.12.2
ansys-dpf-post 0.8.0
ansys-dyna-core 0.4.15
ansys-dynamicreporting-core 0.6.0
ansys-edb-core 0.1.9
ansys-engineeringworkflow-api 0.1.0
ansys-fluent-core 0.22.0
ansys-geometry-core 0.6.6
ansys-grantami-bomanalytics 2.1.1
ansys-grantami-bomanalytics-openapi 3.0.0
ansys-grantami-jobqueue 1.0.1
ansys-grantami-recordlists 1.2.1
ansys-grantami-serverapi-openapi 3.0.0
ansys-grpc-dpf 0.8.1
ansys-hps-client 0.8.0
ansys-mapdl-core 0.68.4
ansys-mapdl-reader 0.53.0
ansys-math-core 0.1.5
ansys-mechanical-core 0.11.5
ansys-mechanical-env 0.1.7
ansys-mechanical-stubs 0.1.4
ansys-meshing-prime 0.6.2
ansys-modelcenter-workflow 0.1.1
ansys-motorcad-core 0.5.5
ansys-openapi-common 2.2.0
ansys-optislang-core 0.8.0
ansys-platform-instancemanagement 1.1.2
ansys-pyensight-core 0.8.8
ansys-pythonnet 3.1.0rc4
ansys-rocky-core 0.2.0
ansys-seascape 0.2.0
ansys-sherlock-core 0.6.0
ansys-simai-core 0.2.2
ansys-sound-core 0.1.3
ansys-systemcoupling-core 0.6
ansys-tools-filetransfer 0.1.1
ansys-tools-local-product-launcher 0.1.1
ansys-tools-path 0.6.0
ansys-tools-visualization-interface 0.6.2
ansys-turbogrid-api 0.4.3
ansys-turbogrid-core 0.4.1
ansys-units 0.3.4
ansys-workbench-core 0.6.0
Thanks in advance!
