How can I export the name of a part from mechanical to Python
def get_body(self): model_path = self.file_path_var.get() raw_list = self.controller.get_body_list(model_path) self.part_list = [str(item) for item in raw_list] self.update_all_comboboxes() def get_body_list(self,model_path): try: server_port = self.wb.start_mechanical_server(system_name='MODEL') self.mechanical = launch_mechanical(start_instance=False, port=server_port) except Exception as e: messagebox.showerror("错误", str(e)) raise script2 = f''' geometry = DataModel.GetObjectById(12) geometry.Import(r"{model_path}") part_list = [part.Name for part in DataModel.GetObjectsByType(DataModelObjectCategory.Part)] return part_list''' part_list = self.mechanical.run_python_script(script2) return part_list
Hi @Mr.G Can you elaborate on your question? I am not sure I understand the issue here.
I designed a GUI interface in PyCharm with a button inside:
‘Button(material_placement_frame, text='确认', command=self.get_body, font='宋体 9', width=5).place(x=200, y=4)
def get_body(self):
self.update_all_comboboxes()’
Clicking this button will run the mechanical script:
‘ def get_body_list(self,model_path):try: server_port = self.wb.start_mechanical_server(system_name='MODEL') self.mechanical = launch_mechanical(start_instance=False, port=server_port) except Exception as e: messagebox.showerror("错误", str(e)) raise script2 = f'''
return part_list'''
return part_list’
I need to return part_list to set options for combobox,But this return value is'['I', 'r', 'o', 'n', 'P', 'y', 't', 'h', 'o', 'n', '.', 'R', 'u', 'n', 't', 'i', 'm', 'e', '.', 'L', 'i', 's', 't']'(IronPython.Runtime.List)
Thank you for your reply0 -
click the button--run mechanical script--return part.name from mechanical to my GUI as a list(part_list)--use the list to be a combobox option
